7 years, 2 months ago.
Mbed FatFileSystem and SDBlock Device unexpected behavior and errors
Hello everyone, I am currently working on WIZnet WIZwiki-7500p, and in my project I need to write some files on a SD Card. The code behaves unexpectedly, as some times it works and some others it fails. Below is my code:
main.cpp
#include "SDFileSystem.h"
#include <stdio.h>
FATFileSystem fs("sd");
SDBlockDevice bd(
MBED_CONF_SD_SPI_MOSI,
MBED_CONF_SD_SPI_MISO,
MBED_CONF_SD_SPI_CLK,
MBED_CONF_SD_SPI_CS
SDFileSystem sd(fs,bd);
InterruptIn irq(PC_6);
void onInterrupt() {
sd.erase();
printf(" Mbed OS filesystem example \n");
irq.fall(mbed_event_queue()->event(onInterrupt));
sd.mount();
for ( unsigned long long int tag = 1547517475; tag < 1547517477 ; tag++ ) {
char out_string [12];
sprintf(out_string, "%llu", tag);
sd.setTimeStampt(out_string);
sd.displayFile("/sd/tagsTimeStampt.txt");
sd.displayFile("/sd/numbers.txt");
printf("Mbed OS filesystem example done!\n");
SDFileSystem.cpp
#ifndef SDFILESYSTEM_H
#define SDFILESYSTEM_H
#include <stdio.h>
#include <errno.h>
#include "FATFileSystem.h"
#include "SDBlockDevice.h"
class SDFileSystem {
private:
FATFileSystem& fs;
SDBlockDevice& bd;
FILE* f;
int err;
public:
SDFileSystem(FATFileSystem& fs , SDBlockDevice& bd);
void setTimeStampt( char* buffer );
void erase();
void mount();
void displayFile(char* path);
#endif
SDFileSystem.h
SDFileSystem::SDFileSystem(FATFileSystem& fs , SDBlockDevice& bd): fs(fs) , bd(bd){
void SDFileSystem::mount(){
printf("Mounting the filesystem... ");
fflush(stdout);
int err = fs.mount(&bd);
printf("%s\n", (err ? "Fail :(" : "OK"));
if (err) {
printf("No filesystem found, formatting... ");
fflush(stdout);
err = fs.reformat(&bd);
if (err) {
error("error: %s (%d)\n", strerror(-err), err);
void SDFileSystem::erase() {
printf("Initializing the block device... ");
fflush(stdout);
int err = bd.init();
if (err) {
printf("Erasing the block device... ");
fflush(stdout);
err = bd.erase(0, bd.size());
if (err) {
printf("Deinitializing the block device... ");
fflush(stdout);
err = bd.deinit();
if (err) {
void SDFileSystem::displayFile( char* path){
printf("\r\nOpening \"%s\"... ", path);
fflush(stdout);
fflush(f);
f = fopen(path, "r");
printf("%s\n", (!f ? "Fail :(" : "OK"));
if (!f) {
error("error: %s (%d)\n", strerror(errno), -errno);
printf("data:\n");
while (!feof(f)) {
int c = fgetc(f);
putc(c, stdout);
fflush(f);
printf("\nClosing \"%s\"... ",path);
err = fclose(f);
printf("%s, err: %d\n", (err < 0 ? "Fail :(" : "OK"), err);
void SDFileSystem::setTimeStampt( char* timestamp ){
printf("\r\nOpening \"/sd/tagsTimeStampt.txt\"... ");
f = fopen("/sd/tagsTimeStampt.txt", "w");
printf("\rWriting timestampt: %s... ", timestamp);
err = fprintf(f, "timestamp: %s\n",timestamp);
fflush(f);
printf("%s, err: %d\n", (err != 0 ? "Fail :(" : "OK"), err);
if (err < 0) {
printf("Fail :(\n");
fflush(stdout);
printf("Closing \"/sd/tagsTimeStampt.txt\"... ");
err = fclose(f);
Results
Success
Mounting the filesystem... OK
Opening "/sd/tagsTimeStampt.txt"... OK
Writing timestampt: 1547517475... Fail :(, err: 22
Closing "/sd/tagsTimeStampt.txt"... OK, err: 0
data:
timestamp: 1547517475
Writing timestampt: 1547517476... Fail :(, err: 22
data:
timestamp: 1547517476
Opening "/sd/numbers.txt"... OK
data:
120
121
122
123
124
125
126
127
128
Closing "/sd/numbers.txt"... OK, err: 0
Fail
Mbed OS filesystem example Mounting the filesystem... OK Opening "/sd/tagsTimeStampt.txt"... Fail :( Writing timestampt: 1547517475... Fail :(, err: 22 Closing "/sd/tagsTimeStampt.txt"... OK, err: 0 Opening "/sd/tagsTimeStampt.txt"... OK data: � Closing "/sd/tagsTimeStampt.txt"... OK, err: 0 Opening "/sd/tagsTimeStampt.txt"... OK Writing timestampt: 1547517476... Fail :(, err: 22 Closing "/sd/tagsTimeStampt.txt"... Fail :(, err: -1 Opening "/sd/tagsTimeStampt.txt"... OK data: � Closing "/sd/tagsTimeStampt.txt"... OK, err: 0 Opening "/sd/numbers.txt"... OK data: ����������������������������������������������������������������������������������������������������� .... (it continues to print this indefinitely....)
Do you know what am I missing to prevent this errors?
