7 years, 2 months ago.
URGENT: Following Mbed server work at weekend can no longer save source file
Hi I can no longer save my online compiler source file, I receive time-out messages from the Mbed server. This started to happen today (Monday) following the Mbed scheduled weekend maintenance outage. I can edit, save and compile smaller projects so am confident something has changed on the Mbed side. This is preventing me from continuing my project so I would appreciate a fast response. Thanks. Chris
Hi Chris,
We are aware that saving and deleting files inside of the Online Compiler has become very slow. It was indeed an unforeseen consequence of the work done during the maintenance on Saturday. We are currently testing a fix for this issue.
Sam
Hi Sam, thanks for your reply. It's still not working. Is there a work-around whilst you test your fix as at present this has put my project on hold? Chris
posted by 15 Jan 2019We pushed a fix for the slow performance yesterday. Can you test again? If you're still having trouble saving let me know.
posted by 16 Jan 2019Hi Sam, still not saving. It's to do with the file size. I've been able to do some offline editing, import the file and then compile successfully. The file is size is 502KB (which is what it was prior to the server changes last weekend).
Hi Sam, it works! Thank you and to the team :)
posted by Chris Mabey 16 Jan 2019
