7 years, 2 months ago.
Mutex lock failed with serial interrupt
I use mbed os 5 with a STM32 Nucleo-L073RZ card.
I have a problem with serial interrupts, I want to do something pretty simple I think, but I have a crash of mbed os.
My code creates two serial ports:
- the standard stdio serial interface used with the ST-link ("serial_pc" in my code)
- a second serial interface on port serial4 (TX: PA_0, RX: PA_1) with receving interrupt enabled ("uart" in my code)
code
Serial serial_pc(SERIAL_TX, SERIAL_RX, 115200);
Serial uart(PA_0, PA_1,9600);
char c;
void isr_uart() {
c = uart.getc();
return;
serial_pc.printf("\n\n*** UART TEST ***\n");
uart.attach(&isr_uart,Serial::RxIrq);
This code compiles and runs fine until I send a char on the serial port named "uart" here (Serial4 on my board), then I get this error :
++ MbedOS Error Info ++ Error Status: 0x80020115 Code: 277 Module: 2 Error Message: Mutex lock failed Location: 0x8005F15 Error Value: 0xFFFFFFFA Current Thread: rtx_idle Id: 0x20000374 Entry: 0x8008041 StackSize: 0x300 StackMem: 0x20000400 SP: 0x20004F08 For more info, visit: https://armmbed.github.io/mbedos-error/?error=0x80020115 -- MbedOS Error Info --
I just want to use a simple Rx interrupt, but I must have missed something right ?
Thank you in advance for you help.
ps: I have tested my code and I don't get this error with mbed 2
Try making that a RawSerial object rather than regular Serial object. Every Serial method is wrapped with mutexes which are unusable in ISR (at least last time I checked). RawSerial does not have mutexes and can be used in ISR. Would be nice if they could fix this in standard Serial class, as it's obviously a super common requirement.
