7 years, 2 months ago.
Documentation not ready
I've created a detailed documentation in my library 'motor.h', 'motor.cpp'. See: https://os.mbed.com/users/sepp_nepp/code/MotorLib/ The compiles under Doxygen locally on my PC without problem. But under mbed it shows 'Documentation not ready'. Is there a way to debug the problem from my side? Or can you please take a look at it?
Thank you very much.
Hi Tarek,
We think the API Documentation has now pulled through (for instance https://os.mbed.com/users/sepp_nepp/code/MotorLib/docs/tip/classMotor.html). Is that what you are expecting to see? If this is your first public project it may have been subject to moderation or perhaps it just took a bit for it to be displayed.
Ralph, Team Mbed
Hi Ralph, Thanks for your fast answer. I think the API documentation under "https://os.mbed.com/users/sepp_nepp/code/MotorLib/docs" is OK. When I publish edits to the source code, they come through immediately. Good.
But locally inside the compiler, I still only get "Documentation not ready". Also, when I import into the compiler as new program, still no documentation inside the compiler.
Anything I forgot to do?
Regards, Tarek
posted by 01 Jan 2019Thanks for clarifying what the problem is. This appears to be on our side, so we've looped in our Web team to have a look at the problem.
posted by 02 Jan 2019
