7 years, 3 months ago.
Where i can see resources used MBED in my project NRF52 BLE?
I was created project on Mbed with my NRF52832 with BLE stack. I do not know where i can see used by mbed resources, so i can not use hardware timers on board. Everebody can help me ? Thank you))
Hello Marat,
There are two branches of MBED:
  • MBED OS-2. It does not use RTOS by default (so it's very similar to Arduino). But you can add it one if you like.
  • A more advanced and complex MBED OS-5 which includes an RTOS by default.
When using the online compiler you are not able to modify the MBED source code, only your application code. However, you can have a look what's under the hoods at he links above.
If you decide to use the Command Line Interface (CLI) then you'll be able to modify MBED source codes as well.
