7 years, 5 months ago.
STM Nucleo L476RG with 8266 and serial passthrough
This is straight forward in arduino, where you simply compile, and type interactively. Every step I tried with the stm I repeated with an arduino successfully.
I cannot figure out how to get this to work with a STM device. It seems that the STM Nucleo L476RG cannot deliver 3.3v, so I made that external power. Depending on what I try it ether hanged, disconnects from serial, just repeats a single character, or now with RawSerial repeats entire line, but it does not at any point appear to actually interact with the device.
Related : https://os.mbed.com/questions/92/serial-PC-to-MBED/ https://os.mbed.com/handbook/USBSerial https://os.mbed.com/handbook/SerialPC
  1. include "mbed.h"
RawSerial pc(USBTX, USBRX); RawSerial dev(D1, D0); RawSerial dev(PA_2,PA_3); DigitalOut led1(LED1); DigitalOut led4(LED4);
void dev_recv() { led1 = !led1; while(dev.readable()) { pc.putc(dev.getc()); } }
void pc_recv() { led4 = !led4; while(pc.readable()) { dev.putc(pc.getc()); } }
int main() { pc.baud(115200); dev.baud(115200);
pc.attach(&pc_recv, Serial::RxIrq); dev.attach(&dev_recv, Serial::RxIrq);
while(1) { sleep(); } }
It does not work correctly because the program is using the same Serial port (Serial2) to communicate with the device and with the PC (check in the PinNames.h) :
PinNames.h
USBTX = PA_2;
USBRX = PA_3;
D1 = PA_2;
D0 = PA_3;
Try to select differennt Serial port for the device. For example Serial1:
RawSerial   pc(USBTX, USBRX);  // Serial2
RawSerial   dev(A4, A5);  // Serial1
//RawSerial   dev(PC_1, PC_0); //Serial1
ADVISE: To have a more readable code after pasting it here (to mbed pages) try to mark it up as below (with <<code>> and <</code>> tags, each on separate line at the begin and end of your code)
<<code>>
text of your code
<</code>>
