7 years, 3 months ago.
UART communication in FRDM k64F
Hi, I need to send this command
uint8_t txbuff[] = "coap CON GET fd61:7409:e1d2:56f2:fd27:3426:5a6b:5f93 /temp\n";
through uart pin of K64F.(PTC 17) to KW41z board. I tried passing it using an array but was not successful. Any pointers on how to do this.
Thanks and Regards Niranjan
Hello Niranjan,
You can try the code below:
DigitalOut led1(LED1);
Serial serial(PTC17, PTC16);
char message[] = "coap CON GET fd61:7409:e1d2:56f2:fd27:3426:5a6b:5f93 /temp\n"; // the compiler silently appends a null char (0x00)
// serial.baud(115200); // Uncomment this line to change the bitrate from default (9600) to 115200
serial.printf("%s", message);
// Uncomment the lines below to send the message periodically each second
// while(true)
// wait(1.0);
// led1 = !led1;
// serial.printf("%s", message);
Rmember to connect K64F's Tx line (pin PTC17) to KW41z's Rx line.
