7 years, 3 months ago.
mDot by AUTO_OTA can't send larger than 11 bytes payloads
Hello! I'm using a mDot and a Multitech Gateway (US915), on the configurations I'm setting the setTxDataRate() like this: dot->setTxDataRate(mDot::DR4); It suppose to change the Spread Factor to 7 and BW to 500 acording to the mdot library, but when I subscribe to the topic on my gateway on the datar It shows: "datr":"SF10BW125"
this is the configuration im using:
void config_dot(){
//static bool adr = true;
static uint8_t join_delay = 5;
dot = mDot::getInstance();
lora_handler = new LoRaHandler(main_id, LED_GREEN, LED_YELLOW);
dot->resetConfig();
dot->resetNetworkSession();
dot->setLogLevel(mts::MTSLog::INFO_LEVEL);
dot->setLogLevel(mts::MTSLog::ERROR_LEVEL);
if (dot->getJoinMode() != mDot::AUTO_OTA) {
logInfo("changing network join mode to AUTO_OTA");
if (dot->setJoinMode(mDot::AUTO_OTA) != mDot::MDOT_OK) {
logError("failed to set network join mode to AUTO_OTA");
update_ota_config_name_phrase(network_name, network_passphrase, frequency_sub_band, public_network, ack);
update_network_link_check_config(3, 5);
//dot->setAdr(true);
dot->setJoinDelay(5);
// save changes to configuration
logInfo("saving configuration");
if (!dot->saveConfig()) {
logError("failed to save configuration");
display_config();
the wired thing is when I use ADR it takes like 15 minutes (trying to send a frame every 30 seconds) to iterate between every DR but at the end it starts sending data without problem and on the topic it shows the Spread factor using is 8 and BW 500 .
It is something im missing on the settings that isn't changing the SF and BW, beacuse I'm calling back the dot->getTxDataRate() function and it shows correct datarate (DR4) but doesnt send any data ever.
Thanks for taking the time to read my question.
