7 years, 4 months ago.  This question has been closed. Reason: Off Topic
Compiler error with MBED library
I have seen an update of the compiler, and it might give problems whit the Mbed.h libary. In our class we use nucleo (Nucleo-F303K8). Today we noticed that most of the example codes wont work enymore (for instance Blinky led, the code wont compile because of a "internal error"). I have made a empty program (that has the bare minimum) and added the mbed.h libary via the import button, this code will also give the "internal error". When I delte the Mbed.h file of that program and copy an older Mbed.h file (from a pervious program) then the error is resolved. Are we doing somthing wrong or is there a issue whit the compiler?
Best regards,
Robert
today I have noticed that the error has been resolved. I have closed this question.
posted by R. Bouwmeester 27 Nov 2018
