7 years, 4 months ago.
How can I get the MBED error output when compiling with PlatformIO?
Hi, I am trying to get the MBED Error output over RTT or Serial, but neither of them works. I read somewhere, that I have to compile the Project with the MBED cli in order to get the error output working.. is that true? and if so, how can i do that on PlatformIO(VSCODE)?
adding to that, I am wondering why Serial output is not working.. I set the serial ports correctly, but I cant use stdout or normal printf for serial... is it maybe due to the fact that I have another Serial Object Instance with the same pins on my main App?
thanks, Jonas
Hi Jonas,
By default, the error output (which is printf()) is re-targeted to Serial port, so if you connect the port well, you should be able to see the output from serial tool(like coolterm or teraterm). I believe it's regardless of the IDE or editor.
I may need the following information from you.
- Could you attach a simple code snippet for printing some logs you are using? And also the board your are using.
- The platform you are using
- How you connect the serial port
- Desmond, team Mbed
Hi, thanks for the answer, I wrote my own Handler for the MBED error messages (overwritten the WEAK mbed_error() function) and by swapping every printf statement with my own serial function I got it to work. The only thing I still dont get is the Fault handler Register dump, which would be nice too!
code for my RTT prints:
RTT
va_list args; va_start(args, fmt); vsprintf(buf,fmt,args); SEGGER_RTT_WriteString(0,buf); va_end(args);
code for my Serial prints:
Serial
va_list args; va_start(args, fmt); cm.mydevice->vprintf(fmt, args); va_end(args);
with mydevice being declared as: this->mydevice = new Serial(P0_29, P0_30);
I am using the Nordic NRF52832 chip with NRF52_DK platform. Serial port is connected over the JLink DK serial output, this definitly works (from my own code) I tried it with freopen() but I also could only get my own printfs to print out.
posted by 27 Nov 2018I think the JLink serial should use P0_6 and P0_8 by default, I will suggest you to try to modify TARGET_NRF52_DK/PinNames.h as below
PinName
//RX_PIN_NUMBER = p8, //TX_PIN_NUMBER = p6, RX_PIN_NUMBER = P0_30, TX_PIN_NUMBER = P0_29
And see if the original printf can print through JLink serial output.
In addition, I believe the default baud rate is 9600, make sure you set the correct parameter.
posted by 28 Nov 2018Hi, It does not work, I modified the pin names earlier in mbed_app.json, and now in the file you specified, both methods didnt make it work. Also uart_hwfc is set to 0.
posted by 28 Nov 2018How about not using the JLink DK serial output, do you have an extra usb-to-serial cable, and directly connect it by pin-to-pin TX/RX?
If it works, then the problem might be related to the board configuration, if it still doesn't work, then the problem might be the printf retarget.
posted by 29 Nov 2018I had it connected to another Serial->usb converter, but it didnt work either...
posted by 03 Dec 2018I tested a little bit and now I think it really has to be an MBED bug..
you can easily reproduce this: create new project with platformIO and MBED framework. use this code:
#include <mbed.h>
//Serial device(P0_29, P0_30, 9600); //tx, rx, <--this
void print_to_serial(const char *fmt, ...) {
va_list args;
//device.vprintf(fmt, args); <--this
va_end(args);
// put your setup code here, to run once:
printf("test from mbed");
wait_ms(100);
print_to_serial("test from main code");
wait_ms(100);
when both lines marked with "this" are uncommented, I get the "test from main code" output. when I comment them, I dont get anything for like 10 seconds and then I get a burst of "test from mbed". It seems like printf writes to a buffer and as soon as it is full, the buffer gets printed.
Ps. the burst contains 1024 characters... could be a hint.
