7 years, 4 months ago.
ANALOG-DIGITAL
Design a program (including the flow chart and code) for the development board NUCLEO-F401RE and that must meets the following requirements: a. When you press a button, an analog-to-digital conversion of the voltage found in a potentiometer must be performed. The maximum voltage value shall be represented by the number 99 and this number shall be represented on a two-digit 7-segment LED display. b. After 0.5 seconds the data must be decremented by 5 units and the new data must be shown on the screen. This process must continue until it is equal to or less than zero.
Affordable and flexible platform to ease prototyping using a STM32F401RET6 microcontroller.
