7 years, 4 months ago.
how can I drive this software program (Mbed) into the LPC11U35 using USB.
I do not know the procedure.
Kindly suggest me as soon as possible.
Regards, zass
Hi Thomas,
If you are using an Mbed-enabled board like the EA LPC11U35 QuickStart Board, then it supports drag-and-drop programming from your host PC. After you connect your host PC to the board over USB, you should see the board mount as a mass storage device (likely named "MBED" or "DAPLINK") and then you can simply drop your program onto the drive. It will then get programmed to flash memory.
If you don't have an Mbed-enabled board, then you can program it through conventional means - do you have a JTAG/ Debug port brought out?
Ralph, Team Mbed
