7 years, 4 months ago.
why cant i connect multiple peripherals to one Central running on MBED?
hi, Im desperately trying to connect one Central device to multiple Peripherals, but I cant get it to work. I always get BLE_ERROR_UNSPECIFIED when I try to connect to the second device. I used the LED example and started to modify it, its attached.
serial log output
[18:17:59:612] connectingadvtest peerAddr[77 b8 b0 61 26 59] rssi -54, isScanResponse 0, AdvertisementType 0, conERR=0 [18:18:00:682] connected! handle = 0connected! handle = 0 scanrestart err=0terminated SD for handle 0 [18:18:06:731] connectingadvtest peerAddr[61 15 fc b7 9d f3] rssi -28, isScanResponse 0, AdvertisementType 0, conERR=11
the first time it connect with error=0, second time I get err=11(unspecified) to reproduce it I used 2 android devices running NRF connect.
any help is highly appreciated! thanks in advance, Jonas /media/uploads/Jwoerner/mbedtest_main.cpp
Hi Jonas,
Could you check the value of these three configuration in mbed_congfig.h?
mbed_config.h
NRF_SDH_BLE_CENTRAL_LINK_COUNT NRF_SDH_BLE_PERIPHERAL_LINK_COUNT NRF_SDH_BLE_TOTAL_LINK_COUNT
It could be the configuration limiting the link count, if so, you could modify the macro value in FEATURE_BLE/targets/{Your Target}/mbed_lib.json
Bedsides this, if you only connect the second one, will it succeed?
- Desmond, team Mbed
Hi, thanks for your reply, CENTRAL_LINK_COUNT = 3 PERIPHERAL_LINK_COUNT = 1
but i didnt find TOTAL_LINK COUNT..
so everything is set up correctly, isnt it? btw, why is it set to 3, the softdevice can handle 20 concurrent connections i think?
and yes, if i only connect the second one, it will work properly.
posted by 16 Nov 2018Ok, i have more infos, I looked further into the MBED librarys and piped the NRF error code to my main code, its NRF_ERROR_CONN_COUNT.
may I suggest to change the library so the error is directly piped through from the NORDIC SDK, this would help a lot I guess.
posted by 16 Nov 2018So, I am finally able to connect more than one device, you pointed me in the right direction, but that MBED error handling cost me 2 days of work because the error wasnt passed through. now I have one question remaining: I changed NRF_SDH_BLE_TOTAL_LINK_COUNT in sdk_config.h and that works, but if I set NRF_SDH_BLE_CENTRAL_LINK_COUNT to something other than 0 my app wont work anymore, why is that?
posted by 16 Nov 2018one more thing, i just ran into: how can/should i change the ram used by MBED in order to give enough ram to the Softdevice?
posted by 16 Nov 2018Thank you for your suggestion, this is really a good point, an appropriate error code always helps, I will discuss this with others.
Could you attach the value of three definitions that makes your app not working? (The case of NRF_SDK_BLE_CENTRAL_LINK_COUNT)
mbed_config.h is the final output file, it's not the input file, if you would like to change some parameters, you have to change them with *.json or sdk_config.h which is for Nordic SDK.
Could you open another question about the ram issue? That will helps other people find the right answer quicker!
posted by 19 Nov 2018Hi, I did some further testing, and it here are the results: mbed_lib.json is all default (CENTRALCOUNT = 10 / PERIPHERALCOUNT = 2) but changing the values didnt do anything anyways...?
sdk_config.h:
NRF_SDH_BLE_PERIPHERAL_LINK_COUNT 1 ; NRF_SDH_BLE_CENTRAL_LINK_COUNT 3 ; NRF_SDH_BLE_TOTAL_LINK_COUNT 4 ; this and anything below works! NRF_SDH_BLE_PERIPHERAL_LINK_COUNT 1 ; NRF_SDH_BLE_CENTRAL_LINK_COUNT 4 ; NRF_SDH_BLE_TOTAL_LINK_COUNT 5 ; this and anything above does not work! NRF_SDH_BLE_PERIPHERAL_LINK_COUNT 1 ; NRF_SDH_BLE_CENTRAL_LINK_COUNT 1 ; NRF_SDH_BLE_TOTAL_LINK_COUNT 5 ; this does also not work! I assume this has to do with RAM management, but i will post a new question. thanks for your help :)
