7 years, 2 months ago.
Issue of Test Automation with IAR and GCC toolchain
Hi there,
I have used the K64F board to run test automation, with IAR toolchain and GCC_ARM. Both toolchain failed. I got the following info, May I have some help please?
mbedgt: greentea test automation tool ver. 1.4.0
mbedgt: test specification file '.\BUILD\tests\K64F\GCC_ARM\test_spec.json' (specified withtest-spec option)
mbedgt: using '.\BUILD\tests\K64F\GCC_ARM\test_spec.json' from current directory!
mbedgt: detecting connected mbed-enabled devices...
mbedgt: detected 1 device
mbedgt: processing target 'K64F' toolchain 'GCC_ARM' compatible platforms... (note: switch set to parallel 1)
mbedgt: running 107 tests for platform 'K64F' and toolchain 'GCC_ARM'
mbedgt: mbed-host-test-runner: started
Exception in thread Thread-3:
Traceback (most recent call last):
File "c:\python27\lib\threading.py", line 801, in bootstrap_inner
self.run()
File "c:\python27\lib\threading.py", line 754, in run
self.target(*self.args, self.kwargs)
File "c:\python27\lib\site-packages\mbed_greentea\mbed_greentea_cli.py", line 489, in run_test_thread
verbose=verbose)
File "c:\python27\lib\site-packages\mbed_greentea\mbed_test_api.py", line 318, in run_host_test
returncode, htrun_output = run_htrun(cmd, verbose)
File "c:\python27\lib\site-packages\mbed_greentea\mbed_test_api.py", line 134, in run_htrun
htrun_output += line.decode('utf-8')
File "c:\python27\lib\encodings\utf_8.py", line 16, in decode
return codecs.utf_8_decode(input, errors, True)
UnicodeDecodeError: 'utf8' codec can't decode byte 0xd2 in position 0: invalid continuationbyte
mbedgt: could not generate test report
mbedgt: completed in 9.60 sec
mbedgt: exited with code -1000
[mbed] Auto-installing missing Python modules...
[mbed] WARNING: Cannot run icetea tests. Current folder does not contain TEST_APPS folder.
[mbed] ERROR: "mbedgt" returned error.
Code: -1000
Path: "D:\mbed-cli\mbed-os-example-blinky"
Command: "mbedgt test-spec .\BUILD\tests\K64F\GCC_ARM\test_spec.json"
Tip: You could retry the last command with "-v" flag for verbose output
I am using the Chinese version Windows 10, it seems that it is the char-set issue. When I switch to English Windows 10. the issue has gone!
It might be the defect of the greentea tools.
thanks. JZ
posted by JZ Qiu 16 Nov 2018
