7 years, 5 months ago.
DISCO-L072CZ-LRWAN1: where do I program it to have a higher spread factor
I have a DISCO-L072CZ-LRWAN1 board which connects with the gateways in Norwich. Back at home, I am unable to connect with the local gateway. A suggestion by the owner is to use a higher spread factor. I have based my development on the mbed-os-example-lorawan code. How do I program Lora PHY to use a higher spread factor? Also is it possible to disable the radio from using all but one channel? Should I disable the ADR? Any guidance much appreciated as I am new to this.
