7 years, 5 months ago.
Problem to display a bmp image using a STM32F413.
Hello everyone I have a question related to STM32F413. I want to show an image using your LCD but the system shows the image with a distortion and I tried a different method with no results. Can you you help me with this?.
This is my code:
main
#include "stm32f413h_discovery.h"
#include "stm32f413h_discovery_ts.h"
#include "stm32f413h_discovery_lcd.h"
//#include "stm32f413h_discovery_sd.h"
#include "tensor.hpp"
#include "image.h"
#include "models/deep_mlp.hpp"
#include "FATFileSystem.h"
#include "F413ZH_SD_BlockDevice.h"
Serial pc(USBTX, USBRX, 115200);
F413ZH_SD_BlockDevice bd;
FATFileSystem fs("fs");
void init_lcd();
void show_message();
void list_files(DIR* dir);
// Read BMP File
void drawImage(char * name, uint8_t x, uint8_t y){
int fileSize;
char * buffer;
FILE *Image = fopen(name, "r+"); // open the bmp file
//obtain file size:
fseek (Image , 0 , SEEK_END);
fileSize = ftell (Image);
rewind (Image);
// allocate memory to contain the whole file:
buffer = (char*) malloc (sizeof(char)*fileSize);
// copy the file into the buffer:
fseek (Image, 0 , SEEK_SET );
// set SD file data start position
fread (buffer,1,fileSize,Image);
//Draw image
//BSP_LCD_DrawBitmap(0, 0, (uint8_t *)buffer);
fclose (Image);
//Free allocated memory
free (buffer);
printf("--------------------------------------------------------------\n");
char * file_to_open = "/fs/smile.bmp";
//ON_ERR(bd.init(), "SDBlockDevice init ");
//ON_ERR(fs.mount(&bd), "Mounting the filesystem on \"/fs\". ");
bd.init();
printf("SDBlockDevice init \n");
fs.mount(&bd);
printf("Mounting the filesystem on \"/fs\". \n");
init_lcd();
FILE* fd = fopen(file_to_open, "rb");
DIR* dir = opendir("/fs/");
list_files(dir);
drawImage("/fs/smile.bmp", 0, 0);
void init_lcd(){
BSP_LCD_Init();
/* Touchscreen initialization */
if (BSP_TS_Init(BSP_LCD_GetXSize(), BSP_LCD_GetYSize()) == TS_ERROR) {
printf("BSP_TS_Init error\n");
BSP_LCD_Clear(LCD_COLOR_WHITE);
void show_message(){
/* Clear the LCD */
/* Set Touchscreen Demo1 description */
BSP_LCD_SetTextColor(LCD_COLOR_GREEN);
BSP_LCD_FillRect(0, 0, BSP_LCD_GetXSize(), 40);
BSP_LCD_SetTextColor(LCD_COLOR_BLACK);
BSP_LCD_SetBackColor(LCD_COLOR_GREEN);
BSP_LCD_SetFont(&Font16);
BSP_LCD_DisplayStringAt(0, 0, (uint8_t *)"Emotion Class Demo", CENTER_MODE);
Have you seen this question? Make sure the bitmap format for the file on the SD card is supported by the library.
