7 years, 5 months ago.
Getc() and putc() 24 bit data
Hi everyone. My problem is: I have to receive data from a sensor on a Nucleo L152RE and to send that data to the PC. My sensor gives in output a datagram of 38 byte. The first byte is an identification-byte (0x93). Then I have 3 3-byte data; a 1-byte data; another 3 3-byte data; a 1-byte data; another 3 3-bytet data; a 1-byte data and so on. I've written the code below in which data are received and send 1 byte at time. When i make the acquisition with MatLab, i have a vector of uint8 data. In the sensor datasheet there are some formulas by which combining, for exemple, the 3 byte of one 3-byte data, it gives me back the proper value of the data in a specified measurement unit (see the figure below the code part). But, all that formulas in the datasheet are with plus (not minus) and the uint8 are positive, so i cannot detect sign variations. My question is: the sign problem is a parsing-part problem (i.e. MatLab problem)? Or i can resolve this problem with a proper software logic in mbed?
RawSerial STIM300(PA_9, PA_10, 460800);
RawSerial portaUSB(USBTX, USBRX, 460800);
DigitalOut led(LED1);
Timer t;
uint8_t buffer[38];
uint8_t app;
    STIM300.format(8,SerialBase::None,1);
    portaUSB.format(8,SerialBase::None,1);
        led = 1;
        do {
            app=STIM300.getc();
        } while(app!=0x93);
        portaUSB.putc(app);
        for(int i=0; i<37; i++) {
            portaUSB.putc(STIM300.getc());
        led=0;
    }//end while 1
}//end main
https://i.postimg.cc/MHJRT0MZ/Cattura.png
Hello Nikolaos,
It can be done on either side. But if you concern about speed then I think a PC will do a floating point computation much faster than a NUCLEO-L152RE. Unfortunately, I do not have any experience with a STIM300 sensor but according to this driver the three bytes carying gyro's data actually represent a signed integer:
struct sensor_value
    signed int value:24;
} __attribute__ ((__packed__));
Then using your formula and the code available for the driver above, gyro's data can be converted to a (signed) double:
double convertGyro2AngularRate(const uint8_t* gyro_data)
    double  gyro_double = 0;
    uint8_t buffer[3];
    double  twopower14 = 16384;  //2^14
    struct sensor_value *gyro_value;
    if (gyro_data != NULL)
        buffer[2] = gyro_data[0];
        buffer[1] = gyro_data[1];
        buffer[0] = gyro_data[2];
        gyro_value = reinterpret_cast<struct sensor_value *>(buffer);
        gyro_double = (double)(gyro_value->value) / twopower14;
    return gyro_double * (M_PI/180.00); //in rad/second
Thank you very much, Zoltan. Finally the problem has been solved in MatLab, but the solution that you have written is interesting. Thanks again.
posted by Nikolaos Dedes 16 Oct 2018
