7 years, 5 months ago.
Unable to use online compiler
When will the Script Not Found error be fixed with the online compiler?
The BBC micro:bit is a pocket-sized, codable computer that allows anyone to get creative with technology. Made possible through a major partnership with 31 organisations, a micro:bit has been given …
DId you find a way to get it working with the CLI ? The linker script error appears both in the conline compiler and the CLI for me.
posted by Jonathan Piat 15 Oct 2018
Hi Martin,
We are aware of the issue with the online compiler and Mbed 2 targets and are currently working on a fix. In the meantime, you can also use the offline Mbed CLI to compile for the micro:bit, a quick start guide for the Mbed CLI is available here: https://os.mbed.com/docs/latest/tutorials/quick-start-offline.html & an easy installation guide is available here: https://os.mbed.com/docs/latest/tools/installation-and-setup.html
In addition, there is also a bug with the micro:bit and the Mbed CLI with the ARM C5 toolchain: https://github.com/ARMmbed/mbed-os/issues/8344 so in order to use the Mbed CLI with the micro:bit you will need to use the GCC_ARM toolchain: https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads
We apologize for the inconvenience. Please let me know if you have any questions!
- Jenny, team Mbed
I tried with an up to date mbed-cli (latest one on github) , the GCC_ARM target and i get the following error :
IndexError: list index out of range
can you indicate a version of mbed-cli that would work.
posted by Jonathan Piat 24 Oct 2018
