7 years, 5 months ago.
How do I merge my repo to the main repo?
Somehow I have managed to get my local copy of the repo out of sync with the main repo. I initially loaded the main repo (2nd one below) into the online compiler and did some work on it. Soon I decided it would be better to work in my own fork and then update the main branch with tested code. So I forked it and began working in my forked branch (I am not even sure how to provide a link to this) and occasionally "updated" the "main" repo, which was evidently the first one below and not the second.
https://os.mbed.com/users/charlesdavidyoung/code/GEO_COUNTER_L432KC/
https://os.mbed.com/teams/Geo-Electronics-Geo-Counter/code/GEO_COUNTER_L432KC/
It is all very confusing. Did the problem start when I forked the code? BTW I cloned my fork to my desktop. My normal workflow is to make changes on my local pc, commit them, push them, and update on the Mbed compiler. Then I compile and test and repeat. When I have a stable version I will update the "main" branch, which is evidently the first one above. I don't know how to get the second branch (the original) synced up with my "local" branch.
I have looked to help with this on your website without luck.
Thanks Charles
Hi Charles,
We see that you've been busy on the fork you created as you have 80 commits. If we understand correctly, you are able to update your fork just fine from the CLI and now you want to merge your updates to the main GEO_COUNTER_L432KC project. To do so, you will need to create a Pull Request so that the maintainer (or owner) of GEO_COUNTER_L423KC project can evaluate your changes and accept them or comment on them.
This procedure is described here:
Ralph, Team Mbed
