7 years, 7 months ago.
I want to use a different port
hello. i'm using STM32L433RC-P board.
I want to use a different pin than the pins defined in the MBED example code. If I use another pin, it will be compiled but not executed. Can I use a different pin than the default pin when using UART or I2C library?
Hi Park,
Can you please provide me with the Mbed example code you are referring to? Also, for drivers such as UART and I2C you can use your own pin definitions in the object declaration the following way:
- Serial UART:
Serial device(PIN_01, PIN_02); // tx, rx - replace PIN_01 and PIN_02 with the pin names on your board - I2C:
I2C i2c(PIN_01, PIN_02); // SDA, SCL - replace PIN_01 and PIN_02 with the pin names on your board
- Jenny, team Mbed
In UART communication CODE: Serial pc(SERIAL_TX, SERIAL_RX); is OK (SERIAL_TX=PA_2,SERIAL_RX=PA_3) but CODE: Serial pc(another UART prot TX, another UART port RX); is ERROR on a usb connection
In I2C communication CODE: I2C i2c(I2C_SDA, I2C_SCL) is available (I2C_SDA=PB_7, I2C_SCL=PB8) but CODE: I2C i2c(PA_10,PA_9) is not available (compile OK, but not work)
what should i do?
posted by 02 Oct 20187 years, 7 months ago.
You can't use another port. I tried to do it, but without success. Meanwhile my mobile applications rises to the top every day, because I buy app store ratings for my mobile application. I know the service who provide low cost ratings and I like it.
