7 years, 5 months ago.
mbed compile fails @ /make.py", line 45, and so on... ...
After complete Install of Linux Mint 18.1, I did 2 complete Fresh re-installs of mbed-cli with pip as of Sept 27 2018, on -> Linux Mint 18.1 KDE Kernel 4.4.0-135-generic 64 bit
I have seen old posts with the same out put on "https://github.com/ARMmbed/mbed-cli/issues/301" and yes I've pip install -r mbed-os/requirements.txt but still I get the same above outcome see the "Traceback"
Thanx...
wolfgangwayalnd7@comcast.net
mbed -v compile
Traceback (most recent call last):
File "/home/wolf/TEST/mbed-os-example-blinky/mbed-os/tools/make.py", line 45, in <module> from tools.options import get_default_options_parser
File "/home/wolf/TEST/mbed-os-example-blinky/mbed-os/tools/options.py", line 24, in <module> from .toolchains import TOOLCHAINS
File "/home/wolf/TEST/mbed-os-example-blinky/mbed-os/tools/toolchains/init.py", line 43, in <module> from ..config import ConfigException
File "/home/wolf/TEST/mbed-os-example-blinky/mbed-os/tools/config/init.py", line 31, in <module> from jsonschema import Draft4Validator, RefResolver
File "/home/wolf/.local/lib/python2.7/site-packages/jsonschema/init.py", line 18, in <module> from jsonschema.validators import (
File "/home/wolf/.local/lib/python2.7/site-packages/jsonschema/validators.py", line 8, in <module> import requests
File "/home/wolf/.local/lib/python2.7/site-packages/requests/init.py", line 95, in <module> from urllib3.contrib import pyopenssl
File "/home/wolf/.local/lib/python2.7/site-packages/urllib3/contrib/pyopenssl.py", line 46, in <module> import OpenSSL.SSL
File "/usr/lib/python2.7/dist-packages/OpenSSL/init.py", line 8, in <module> from OpenSSL import rand, crypto, SSL
File "/usr/lib/python2.7/dist-packages/OpenSSL/SSL.py", line 118, in <module> SSL_ST_INIT = _lib.SSL_ST_INIT
AttributeError: 'module' object has no attribute 'SSL_ST_INIT'
[mbed] ERROR: "/usr/bin/python" returned error. Code: 1
Path: "/home/wolf/TEST/mbed-os-example-blinky"
Command: "/usr/bin/python -u /home/wolf/TEST/mbed-os-example-blinky/mbed-os/tools/make.py -t GCC_ARM -m disco_f469ni source . build ./BUILD/DISCO_F469NI/GCC_ARM"
Hi Wolfgang,
Please try the following commands:
pip uninstall pyopenssl
then
pip install pyopenssl
Please let me know if that resolves your errors.
- Jenny, team Mbed
