7 years, 6 months ago.
How can I change pins for SPI (STM32F413H-DICO)
Hi everyone, I am using 32F413HDISCO and a simple SPI demo-program: "nucleo_spi_master". On this special board there seems to be an conflict with the WiFi module which uses the same line to SPI MISO (PB_4). So I tried to switch to other pins of the Arduino connector (CN6-CN9). But every time I when change a pin in the mbed::SPI function I got an "pinmap mismatch" error massage.
What's my mistake, how can I change the SPI pins?
my code is:
- include "mbed.h"
- include "SPI.h"
SPI device(SPI_MOSI, SPI_MISO, SPI_SCK); DigitalOut chipselect(SPI_CS); DigitalOut led(LED1);
int main() { int i = 0; device.format(8,0); device.frequency(100); while(1) { led = !led; chipselect=0; device.lock(); device.write(i++); device.unlock(); chipselect=1; wait_ms(200); } }
Hello Jens,
It seems that there are no additional SPI pins available at the Arduino headers.
Have you tried to deselect the WiFi module by pulling up the WIFI_SPI_CSN pin (PG_11)?
#include "SPI.h"
DigitalOut wifi_cs(PG_11);
int i = 0;
device.format(8,0);
wifi_cs = 1; // deselect WiFi SPI slave
chipselect = 1;
led = !led;
chipselect=0;
device.lock();
device.write(i++);
device.unlock();
chipselect=1;
wait_ms(200);
Another option could be to keep the WiFi module in RESET mode:
#include "SPI.h"
DigitalOut wifi_rst(PH_1);
int i = 0;
device.format(8,0);
wifi_rst = 0; // keep WiFi in reset mode
chipselect = 1;
led = !led;
chipselect=0;
device.lock();
device.write(i++);
device.unlock();
chipselect=1;
wait_ms(200);
