7 years, 6 months ago.
How to configure a --library build of mbedOS?
I want to build a library of mbedOS so that I can link multiple applications to it.
I can build the library using e.g:
$ mbed compile -m K64F -t GCC_ARM --library --profile tools/profiles/debug.json
This gives me the expected build results under BUILD.
However, I need to change some of the configuration options for the library being built. I had hoped I could do this using the app-config parameter and point it at a file containing a suitable "target_overrides" object e.g.
$ mbed compile -m K64F -t GCC_ARM --app-config lib-conf.json --library --profile tools/profiles/debug.json
[lib-conf.json]
"name": "nick-application",
"target_overrides": {
"platform.stdio_flush_at_exit": true,
"platform.stdio_convert_newlines" : false,
"platform.stdio_flush_at_exit" : true,
"platform.stdio_baud_rate" : 115200,
"platform.default_serial_baud_rate": 115200
This doesn't work. The app-config parameter is ignored. You can specify an invalid file path or corrupt the contents of a valid file and its completely ignored. If you remove the -library option then the -app-config file is found and processed correctly to generate the expected mbed_config.h contents.
This also affects the configuration of mbedtls as the only way to do that (short of editing the config.h file) is to specify the following somewhere:
"macros": ["MBEDTLS_USER_CONFIG_FILE=\"mbedtls-config-changes.h\""]
So the question is, how do I configure a library build of mbedOS?
$ mbed -version 1.8.1
Thanks
Hi Nick,
I would try the following steps to use the same Mbed OS library for multiple projects with app config files: https://github.com/armmbed/mbed-cli#managing-multiple-mbed-projects
- Jenny, team Mbed
Hi Jenny, Thanks for the follow up. The article doesn’t cover the specific issue I am trying to solve. It’s not so much about how I use the resulting library but how to configure the build when compiling the library at the start of the process. It’s very easy to reproduce the reported behaviour on the command line. Thanks
posted by 20 Sep 2018
