7 years, 6 months ago.
Dot examples compile error
I just tried to compile the ota and auto-ota examples in the latest Dot-Examples commit. It was successful when I use update_ota_config_name_phrase() function, however, when I changed to update_ota_config_id_key() function and commented the other one, every time I got this error"Error: Undefined symbol update_ota_config_id_key(unsigned char*, unsigned char*, unsigned char, bool, unsigned char) (referred from /build/examples/src/auto_ota_example.XDOT_L151CC.o)."
It was very very very frustrating! You even haven't started to do some real coding but just changed a line a code that should definitely work, however, you couldn't even find a clue that why it is not! Please help to solve it.
The reason is, the function declaration update_ota_config_id_key() in xdot_util.h is not consistent with the one in xdot_util.cpp.
posted by Yu LiU 13 Sep 2018Hello Yu,
A fix has just been pushed for the issue you have observed. Sorry for the inconvenience.
Evan
posted by Evan Hosseini 13 Sep 2018
