7 years, 6 months ago.
MacOS can't find my NUCLEO-L433RC-P
Hi all! I bought a NUCLEO-L433RC-P, and have been trying to experiment with it. Unfortunately, I haven't got very far because MacOS doesn't seem to be recognizing that it's connected to my computer. It is plugged in with a simple USB cable.
https://imgur.com/q874WvK
I've tried multiple different cables, two different MacBook Pros, and all available USB ports on each MacBook. I have not modified the jumpers at all. When plugged in, the Nucleo's LD3 LED is lit green and not flashing, the LD4 LED is green and flashing quickly, and the LD1 LED is red and flashing slowly.
I was hoping to try MBed, but have also tried stlink and openocd to make sure that it wasn't a software problem. Neither tool could find the Nucleo - output of each is below.
$ st-util
st-util 1.4.0
2018-09-06T19:46:45 WARN usb.c: Couldn't find any ST-Link/V2 devices
$ openocd -f interface/stlink-v2-1.cfg -f target/stm32l4x.cfg
Open On-Chip Debugger 0.10.0
Licensed under GNU GPL v2
For bug reports, read
        http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 500 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 500 kHz, using 480 kHz
Info : clock speed 480 kHz
Error: open failed
in procedure 'init'
in procedure 'ocd_bouncer'
My MacOS version is Sierra 10.12.6.
Any idea what is going wrong here?
So after trying 2 MacBook Pros, a Windows desktop, all USB ports on the previously mentioned devices, a USB hub, two different cables, and ordering a new board that also didn't work, I ordered a brand new, third cable...which worked with both boards.
posted by Tyler Wilcock 13 Sep 2018
