7 years, 7 months ago.
I2C Communication
I am having L3G4200D gyroscope sensor communicate to Mbed LPC 1768 Through I2C. I manage to get the correct output if I only read the output of one axis. The output angle is not right when I want to read the data from all axis. The output is reduced and gives me around 20 degrees when I actually turned about 90 degrees. It seems that all of the axes are having the same issue and the errors are constant. Anyone experience this issue before?
I2C i2c(p9, p10);
Serial pc(USBTX, USBRX);
Thread angleThread;
const int Addr_Write = 0xD2;
const int Addr_Read = 0xD3;
const int regAddr = 0x0F;
const int CTRL_REG1 = 0x20;
const int CTRL_REG2 = 0x21;
const int CTRL_REG3 = 0x22;
const int CTRL_REG4 = 0x23;
const int CTRL_REG5 = 0x24;
const int OUT_X_H = 0x29;
const int OUT_X_L = 0x28;
const int OUT_Y_H = 0x2B;
const int OUT_Y_L = 0x2A;
const int OUT_Z_H = 0x2D;
const int OUT_Z_L = 0x2C;
char data_WhoAmI[1] = {0};
char data_xH[1] = {0};
char data_xL[1] = {0};
char data_yH[1] = {0};
char data_yL[1] = {0};
char data_zH[1] = {0};
char data_zL[1] = {0};
float sensitivity = 0.0175;
float x_dAngle = 0.0000;
float y_dAngle = 0.0000;
float z_dAngle = 0.0000;
float x_angle = 0.0000;
float y_angle = 0.0000;
float z_angle = 0.0000;
float sum = 0.0000;
float offset = 0.0000;
float dt = 0.02;
int16_t x_combineValue = 0;
int16_t y_combineValue = 0;
int16_t z_combineValue = 0;
void readData() {
    char xAxis_H[1] = {OUT_X_H};
    i2c.write(Addr_Write, xAxis_H, 1);
    i2c.read(Addr_Read, data_xH, 1);
    char xAxis_L[1] = {OUT_X_L};
    i2c.write(Addr_Write, xAxis_L, 1);
    i2c.read(Addr_Read, data_xL, 1);
    x_combineValue = data_xH[0] << 8 | data_xL[0];
    char yAxis_H[1] = {OUT_Y_H};
    i2c.write(Addr_Write, yAxis_H, 1);
    i2c.read(Addr_Read, data_yH, 1);
    char yAxis_L[1] = {OUT_Y_L};
    i2c.write(Addr_Write, yAxis_L, 1);
    i2c.read(Adrr_Read, data_yL, 1);
    y_combineValue = data_yH[0] << 8 | data_yL[0];
    char zAxis_H[1] = {OUT_Z_H};
    i2c.write(Addr_Write, zAxis_H, 1);
    i2c.read(Addr_Read, data_zH, 1);
    char zAxis_L[1] = {OUT_Z_L};
    i2c.write(Addr_Write, zAxis_L, 1);
    i2c.read(Addr_Read, data_zL, 1);
    z_combineValue = data_zH[0] << 8 | data_zL[0];
    wait_ms(20);
/* void calibration() {
    pc.printf("Calibrating Offset...");
    for (int i=0; i<200; i++){
        readData();
        z_dAngle = sensitivity* z_combineValue;
        sum = sum + z_dAngle*dt;
    offset = sum/200;
void readGyro() {
        readData();
        x_dAngle = sensitivity * x_combineValue;
        x_angle = x_angle + x_dAngle*dt;
        y_dAngle = sensitivity * y_combineValue;
        y_angle = y_angle + y_dAngle * dt;
        z_dAngle = sensitivity * z_combineValue;
        z_angle = z_angle + z_dAngle*dt;
        pc.printf("%f %f %f\n", x_angle, y_angle, z_angle);
    i2c.frequency(400000);
    char WHO_AM_I[1] = {regAddr};
    i2c.write(Addr_Write, WHO_AM_I, 1);
    i2c.read(Addr_Read, data_WhoAmI, 1);
    pc.printf("SAD is 0x%X\n", data_WhoAmI[0]);
    char ctrl_reg1[2] = {CTRL_REG1,0xBF};
    i2c.write(Addr_Write, ctrl_reg1, 2);
    char ctrl_reg2[2] = {CTRL_REG2, 0x00};
    i2c.write(Addr_Write, ctrl_reg2, 2);
    char ctrl_reg3[2] = {CTRL_REG3, 0x00};
    i2c.write(Addr_Write, ctrl_reg3, 2);
    char ctrl_reg4[2] = {CTRL_REG4, 0x10};
    i2c.write(Addr_Write, ctrl_reg4, 2);
    char ctrl_reg5[2] = {CTRL_REG5, 0x00};
    i2c.write(Addr_Write, ctrl_reg5, 2);
    wait(0.5);
    angleThread.start(readGyro);
