7 years, 7 months ago.
I2C Pins on DISCO-L072CZ-LRWAN1
Hi! I am new to MBED and trying to use I2C peripheral of the STM32L072CZY. I checked the microcontroller reference manual for pin functions and connected I2C sensor as follows:
PB9 --> I2C1_SDA
PB8 --> I2C1_SCL
The I initialized I2C with following code:
I2C My_i2c(PB_8 , PB_9 );
I put serial terminal to the PA2/PA3 pins and got following message:
++ MbedOS Error Info ++
Error Status: 0x80010130 Code: 304 Module: 1
Error Message: pinmap not found for peripheral
Error Value: 0xFFFFFFFF
Current Thread: Id: 0x20002618 Entry: 0x8014E69 StackSize: 0x400 StackMem: 0x20002218 SP: 0x20002500
MbedOS Error Info
Is there a limited subset of the possible pin remapping compared to actual microcontroller reference manual?
Thanks for any help.
The I2C pins should be declared as below:
I2C i2c(PB_9, PB_8); // SDA, SCL
