7 years, 7 months ago.
How to use BusOut inside of class?
Hello everyone!
I'm trying to use BusOut inside of class initialization as private part, but I receive error:
Error text
uninitialized reference member in 'class mbed::BusOut&' [-fpermissive]
no default constructor exists for class "mbed::BusOut",
The basic of code is:
The code
#include <mbed.h>
class indicator {
    private:
        BusOut bus;
    public:
        indicator (PinName A1, PinName A2, PinName A3, PinName A4, PinName A5, PinName A6, PinName A7, PinName A8) {
            bus = BusOut(A8, A7, A6, A5, A4, A3, A2, A1);
indicator demonstator (PB_8, PB_9, PB_3, PA_15, PA_12, PB_6, PB_5, PB_4);
    // put your setup code here, to run once:
Target board : BluePill (STM32F103C8T6)
Hello Yehor,
Rather then using an assignment, try to initialize the bus with a class member initializer. For example as below:
class   indicator
private:
    BusOut  bus;
public:
    indicator(PinName A1, PinName A2, PinName A3, PinName A4, PinName A5, PinName A6, PinName A7, PinName A8) :
        bus(A8, A7, A6, A5, A4, A3, A2, A1)
NOTE: The assignement does not work in your case because the line below
bus = BusOut(A8, A7, A6, A5, A4, A3, A2, A1);  // this is not an initializer but rather an assignement!
requires to first create a temporary bus object and then assing an object to it. So the compiler is trying to call a default BusOut constructor (a constructor without parameters), however no such exists.
