7 years, 7 months ago.
Serial Communication using MBED OS
I am using the board GAPUINO that uses GAP8 processor. Based on the documentation of the GAP8, mbed os is supported and can be used. So I downloaded the SDK from greenwaves (company who created the GAP8). In the SDK, there is MBED OS with some examples. So, I tried serial communication with a sensor using UART and I succeeded to send and receive data using BAUD 115200. My problem is when I try to print Data (using printf()) in order to see what I am receiving. If I call printf while reading on serial, I don't received all the data anymore. I cant find the link between serial communication and printf. Do someone know the reason of this problem? Thanks in advance.
Regards, Antony
Hello, I have just started using the Gapuino and now I am trying to use a uart module to send data but I am not even sure if I have the correct pins connected . Could you walk me through the process you went to connect the device and set it up.
Regards, Panagiotis
posted by Panagiotis Nomikos 10 Jun 2019
Hi Antony,
Since the GAPUINO is a RISC-V architecture, it is not supported in our Mbed OS repo. Therefore, you will need to either look at GreenWaves website here: https://greenwaves-technologies.com/manuals/BUILD/MBED-OS/html/index.html or post your question here: https://github.com/GreenWaves-Technologies/gap_sdk.
- Peter, team Mbed
