7 years, 7 months ago.
PWM on nRF52 (uBlox Nina-b1)
I need PWM for a project I am using the uBlox nina-b1 module on. Anytime I try to load a code that uses PwmOut the module freezes. From what Ive read in the forum it seems like there is some issue with mbed and the nRF timers . Is there a good way to get around this? Maybe using a lower level call the nordic SDK functions? Any help would be greatly appreciated.
Thanks, Calvin
Hi Calvin,
What version of Mbed are you using?
A problem impacting the PWM on v5.9.1 and later was recently identified for the Nordic nRF52 family and you might be hitting the same issue. A pull request (which also fixes another PWM issue) is under review, please see:
If you are using v5.9.1 you can try to use this commit if you can't wait for the review:
-Ralph, Team Mbed
Note: Post updated to include screen capture:
Thanks for getting back to me Ralph.
I am using the online compiler (not sure how to check version number). I see 1.10.14.0 in the top corner but that doesnt seem like the right number format. I updated all the libraries/docs for my project and the program still hangs when I try to use PwmOut.
posted by 13 Aug 2018Hi Calvin,
If you are using the Online Compiler try reverting back to Mbed OS v5.9. I will update my original post to include a screen capture which shows how to do this. In summary, the steps are:
- Select mbed-os in the Program Workspace
- Select Revision from the top menu
- Select mbed-os-5.9.0 from the top table (the screen capture shows v5.9.1 being selected)
- Right-click mbed-os-5.9.0 and select "Switch working copy to this revision"
- De-select Revision to return to the Program Workspace code view
Note: The selected OS version will show as bold if you want to double-check which is selected
Then you can rebuild your project. Hopefully you'll see the PWM working as expected.
-Ralph, Team Mbed
posted by 14 Aug 2018Looks like v5.9.0 works with PWM. I tried v5.9.5 and it does not appear to work. Could you walk me through using the commit you suggested to apply the fix to 5.9.5?
edit: Can you comment on Sleep/DeepSleep functionality back to v5.9.0? I had a code that was idling at 3.5mA and with the v5.9.0 commit it is idling at about 8.5mA. I implemented some PWM driving and switched to the older version. I tried commenting out PWM function in case that was keeping it from sleeping but it does not seem to fix the issue.
I wasnt seeing a way to turn off a PWM signal (writing it to "0.0f" freezes the device. Is there a way to write the pin low?
Thanks again
posted by 16 Aug 2018
