7 years, 7 months ago.
Offline mbed-simulator not working
/media/uploads/mpule/mbed-simulator_error1.png Hello,
I'm new to Mbed and I have installed Mbed-CLI, Emscripten SDK and Node.js 8.11.3 LTS. When I try to run the command "mbed-simulator ." from the "mbed-os-example-blinky" I get the error shown in the image (/media/uploads/mpule/mbed-simulator_error1.png ).
Could you please assist with setting it up properly.
Hi there,
I've spoken with Jan (the creator of the Mbed Simulator tool) and he tracked down the issue and has pushed a fix to the Mbed Simulator repository. If you've installed Mbed Simulator with npm please use the following command to update your installation: npm update mbed-simulator -g
- Jenny, team Mbed
Thanks for your response.
I have updated my mbed-simulator installation and when I run the command "sh build-demos.sh" following the instructions on the repository, I still get the following result:
C:\emsdk\node\8.9.1_64bit\bin\node_modules\mbed-simulator>sh build-demos.sh Building demos/bd... libmbed.bc does not exist. Building... 'mbed deploy' did not run before, running...
posted by Mompoloki Pule 16 Aug 2018
