7 years, 8 months ago.
SPI1 as Slave in DISCO_L475VG_IOT0A1
Hi My Code is like below
SPI Slave Code not working
//SPI dwm(PA_7, PA_6, PA_5); // mosi, miso, sclk,cs
//DigitalOut cs(PA_2);
SPISlave device(PA_7, PA_6, PA_5, PA_2); // mosi, miso, sclk, ssel
pc.baud(115200);
pc.printf("in main\n");
If I use SPI1 (CN1 connector on the STM32l475 board) as master I see print on console.
If I use as Slave by declaring SPISlave(..) and commenting SPI Master code.
I do not see any print.
Does that mean SPISlave is not supported ? or am I missing something ?.
NOTE:I have not connected the peripheral.
Can some one help me please .
Can you use PA_4 instead of PA_2?
Thanks for the reply, I am able to see the print, does that mean PA_4 is the Slave select pin not PA_2. I saw on Board Cover PA2(D10) as CS, is PA_2 not SSel . please help.
posted by 07 Aug 2018Yeah, according to this page, PA_4 or PA_15 is used as SPI1_SSEL. You can double-check this in this source code, too.
