7 years, 8 months ago.
How to download .hex file instead of .bin file on new mbed-os version
Hi guys =)
I'm working with mbed online compiler and mbed cli for a while (almost three years- oh yeah!) and I had tons of problems :D
The newest one is that mbed online compiler generates .bin file instead of .hex. I know that's setting within make file that I can not change in online compiler. I'm developing for NRF52_DK and I know for many tools for bin<->hex conversion (like arm-none-eabi-objcopy) but for some other reasons it would be much better for me to get .hex file after compilation.
Do you have any info is there somewhere secret setting? I used to use .json file for some additional settings for UART but can find anything online related to my current problem.
Thank you, jurica238814
Hello Jurica,
To download a hex file instead of a bin file from the online compiler, you will need to add a target.json file to your working directory and override the output extension. More reference here: https://os.mbed.com/docs/v5.9/tools/adding-and-configuring-targets.html
For example:
Overriding K64F to output hex
"K64F": {
    "core": null,
    "default_toolchain": "ARM",
    "supported_toolchains": null,
    "extra_labels": [],
    "is_disk_virtual": false,
    "macros": [],
    "OUTPUT_EXT": "hex",
    "detect_code": [],
    "public": false
- Peter, team Mbed
Hi Petar, thank you for your reply.
I added target.json file into my project but still the same problem. Compilation and build process give me .bin file only. Here's the json file added into my project:
"NRF52_DK": {
    "core": null,
    "macros": [],
    "detect_code": [],
    "public": false
Thank you, Jurica.
posted by Jurica Resetar 06 Aug 2018
