7 years, 8 months ago.
mbed led bluetooth examples does not compile
The mbed bluetooth controlled led exapmple for nrf52_dk target does not compile. first it is missing device.h and then it misses cmsis.h.
By the way: The Helaththermo application does comoile but if you try to connect to it using LightBlue on ios10 it will not connect.
What is wrong...
Hello Medard,
Are you using the offline compiler or the online compiler? if you are using the offline compiler, then you might have to type mbed deploy to import the correct dependency. If you are using the online compiler, then you need to import the correct files into the compiler.
- Peter, team Mbed
