7 years, 8 months ago.
nRF52840 FATFileSystem & sd card boot error
Hello mbed forum,
The 'sd-driver' library works well on my custom nRF52840 board, but only after a 40 second delay at boot. Simply declaring the FATFileSystem causes the boot delay. Example:
This code causes a 40s delay everytime the NRF is repowered, then the led will blink:
DigitalOut redled(p6);
SDBlockDevice sd(p4, p5, p3, p2);
FATFileSystem fs("sd", &sd); //Line causes critical ~40sec delay in NRF boot -- otherwise works
for(;;) {
redled=!redled;
wait(.1);
This code works perfectly (no delay):
//FATFileSystem fs("sd", &sd); //Line causes critical ~40sec delay in NRF boot -- otherwise works
for(;;) {
redled=!redled;
wait(.1);
I'm using mbed-os-5.9 and the latest sd-driver library.
Let me know if you have any ideas, thank you~
Matt
Hello Matthew,
Can you try applying this PR in your sd-driver library: https://github.com/ARMmbed/sd-driver/pull/104? Hopefully, this will fix that issue, this PR has not merge yet is because it is currently under testing.
- Peter, team Mbed
