7 years, 8 months ago.
I build the bluetooth samples using online compiler but i unable to pair the microbit
I've search and managed to tweak my MicroBitConfig.h to disable dfu and event services and set the MICROBIT_SD_GATT_TABLE_SIZE to 0x600.
// Enable/Disable BLE Service: MicroBitDFU // This allows over the air programming during normal operation. // Set '1' to enable. #ifndef MICROBIT_BLE_DFU_SERVICE //#define MICROBIT_BLE_DFU_SERVICE 1 #define MICROBIT_BLE_DFU_SERVICE 0 #endif // Enable/Disable BLE Service: MicroBitEventService // This allows routing of events from the micro:bit message bus over BLE. // Set '1' to enable. #ifndef MICROBIT_BLE_EVENT_SERVICE //#define MICROBIT_BLE_EVENT_SERVICE 1 #define MICROBIT_BLE_EVENT_SERVICE 0 #endif // The amount of memory allocated to Soft Device to hold its BLE GATT table. // For standard S110 builds, this should be word aligned and in the range 0x300 - 0x700. // Any unused memory will be automatically reclaimed as HEAP memory if both MICROBIT_HEAP_REUSE_SD and MICROBIT_HEAP_ALLOCATOR are enabled. #ifndef MICROBIT_SD_GATT_TABLE_SIZE //#define MICROBIT_SD_GATT_TABLE_SIZE 0x300 #define MICROBIT_SD_GATT_TABLE_SIZE 0x600 #endif
I successfully compile and update my MicrBit device.
Able to go into pairing mode and generation of random passkey. After, entering the correct passkey, the phone report that i have entered a wrong passkey. On the other hand, the MiroBit device displays a tick mark.
Please help!@!!!!!!!!!!!
/* The MIT License (MIT) Copyright (c) 2016 British Broadcasting Corporation. This software is provided by Lancaster University by arrangement with the BBC. Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. */ /** * Compile time configuration options for the micro:bit runtime. */ #ifndef MICROBIT_CONFIG_H #define MICROBIT_CONFIG_H #include "mbed.h" #include "yotta_cfg_mappings.h" // // Memory configuration // // The start address of usable RAM memory. #ifndef MICROBIT_SRAM_BASE #define MICROBIT_SRAM_BASE 0x20000008 #endif // Physical address of the top of SRAM. #ifndef MICROBIT_SRAM_END #define MICROBIT_SRAM_END 0x20004000 #endif // The end address of memory normally reserved for Soft Device. #ifndef MICROBIT_SD_LIMIT #define MICROBIT_SD_LIMIT 0x20002000 #endif // The physical address in memory of the Soft Device GATT table. #ifndef MICROBIT_SD_GATT_TABLE_START #define MICROBIT_SD_GATT_TABLE_START 0x20001900 #endif // Physical address of the top of the system stack (on mbed-classic this is the top of SRAM) #ifndef CORTEX_M0_STACK_BASE #define CORTEX_M0_STACK_BASE MICROBIT_SRAM_END #endif // Amount of memory reserved for the stack at the end of memory (bytes). #ifndef MICROBIT_STACK_SIZE #define MICROBIT_STACK_SIZE 2048 #endif // Physical address of the end of mbed heap space. #ifndef MICROBIT_HEAP_END #define MICROBIT_HEAP_END (CORTEX_M0_STACK_BASE - MICROBIT_STACK_SIZE) #endif // Enables or disables the MicroBitHeapllocator. Note that if disabled, no reuse of the SRAM normally // reserved for SoftDevice is possible, and out of memory condition will no longer be trapped... // i.e. panic() will no longer be triggered on memory full conditions. #ifndef MICROBIT_HEAP_ALLOCATOR #define MICROBIT_HEAP_ALLOCATOR 1 #endif // Block size used by the allocator in bytes. // n.b. Currently only 32 bits (4 bytes) is supported. #ifndef MICROBIT_HEAP_BLOCK_SIZE #define MICROBIT_HEAP_BLOCK_SIZE 4 #endif // The proportion of SRAM available on the mbed heap to reserve for the micro:bit heap. #ifndef MICROBIT_NESTED_HEAP_SIZE #define MICROBIT_NESTED_HEAP_SIZE 0.75 //#define MICROBIT_NESTED_HEAP_SIZE 0.6 #endif // If defined, reuse any unused SRAM normally reserved for SoftDevice (Nordic's memory resident BLE stack) as heap memory. // The amount of memory reused depends upon whether or not BLE is enabled using MICROBIT_BLE_ENABLED. // Set '1' to enable. #ifndef MICROBIT_HEAP_REUSE_SD #define MICROBIT_HEAP_REUSE_SD 1 #endif // The amount of memory allocated to Soft Device to hold its BLE GATT table. // For standard S110 builds, this should be word aligned and in the range 0x300 - 0x700. // Any unused memory will be automatically reclaimed as HEAP memory if both MICROBIT_HEAP_REUSE_SD and MICROBIT_HEAP_ALLOCATOR are enabled. #ifndef MICROBIT_SD_GATT_TABLE_SIZE //#define MICROBIT_SD_GATT_TABLE_SIZE 0x300 #define MICROBIT_SD_GATT_TABLE_SIZE 0x600 #endif // // Fiber scheduler configuration // // Scheduling quantum (milliseconds) // Also used to drive the micro:bit runtime system ticker. #ifndef SYSTEM_TICK_PERIOD_MS #define SYSTEM_TICK_PERIOD_MS 6 #endif // // Message Bus: // Default behaviour for event handlers, if not specified in the listen() call // // Permissable values are: // MESSAGE_BUS_LISTENER_REENTRANT // MESSAGE_BUS_LISTENER_QUEUE_IF_BUSY // MESSAGE_BUS_LISTENER_DROP_IF_BUSY // MESSAGE_BUS_LISTENER_IMMEDIATE #ifndef EVENT_LISTENER_DEFAULT_FLAGS #define EVENT_LISTENER_DEFAULT_FLAGS MESSAGE_BUS_LISTENER_QUEUE_IF_BUSY #endif // // Maximum event queue depth. If a queue exceeds this depth, further events will be dropped. // Used to prevent message queues growing uncontrollably due to badly behaved user code and causing panic conditions. // #ifndef MESSAGE_BUS_LISTENER_MAX_QUEUE_DEPTH #define MESSAGE_BUS_LISTENER_MAX_QUEUE_DEPTH 10 #endif // // Core micro:bit services // // To reduce memory cost and complexity, the micro:bit allows components to register for // periodic callback events during interrupt context, which occur every scheduling quantum (FIBER_TICK_PERIOD_MS) // This defines the maximum size of interrupt callback list. #ifndef MICROBIT_SYSTEM_COMPONENTS #define MICROBIT_SYSTEM_COMPONENTS 10 #endif // To reduce memory cost and complexity, the micro:bit allows components to register for // periodic callback events when the processor is idle. // This defines the maximum size of the idle callback list. #ifndef MICROBIT_IDLE_COMPONENTS #define MICROBIT_IDLE_COMPONENTS 6 #endif // // BLE options // // The BLE stack is very memory hungry. Each service can therefore be compiled in or out // by enabling/disabling the options below. // // n.b. The minimum set of services to enable over the air programming of the device will // still be brought up in pairing mode regardless of the settings below. // // Enable/Disable BLE during normal operation. // Set '1' to enable. #ifndef MICROBIT_BLE_ENABLED #define MICROBIT_BLE_ENABLED 1 #endif // Enable/Disable BLE pairing mode mode at power up. // Set '1' to enable. #ifndef MICROBIT_BLE_PAIRING_MODE #define MICROBIT_BLE_PAIRING_MODE 1 #endif // Enable/Disable the use of private resolvable addresses. // Set '1' to enable. // n.b. This is known to be a feature that suffers compatibility issues with many BLE central devices. #ifndef MICROBIT_BLE_PRIVATE_ADDRESSES #define MICROBIT_BLE_PRIVATE_ADDRESSES 0 #endif // Convenience option to enable / disable BLE security entirely // Open BLE links are not secure, but commonly used during the development of BLE services // Set '1' to disable all secuity #ifndef MICROBIT_BLE_OPEN #define MICROBIT_BLE_OPEN 0 #endif // Configure for open BLE operation if so configured #if (MICROBIT_BLE_OPEN == 1) #define MICROBIT_BLE_SECURITY_LEVEL SECURITY_MODE_ENCRYPTION_OPEN_LINK #define MICROBIT_BLE_WHITELIST 0 #define MICROBIT_BLE_ADVERTISING_TIMEOUT 0 #define MICROBIT_BLE_DEFAULT_TX_POWER 6 #endif // Define the default, global BLE security requirements for MicroBit BLE services // May be one of the following options (see mbed's SecurityManager class implementaiton detail) // SECURITY_MODE_ENCRYPTION_OPEN_LINK: No bonding, encryption, or whitelisting required. // SECURITY_MODE_ENCRYPTION_NO_MITM: Bonding, encyption and whitelisting but no passkey. // SECURITY_MODE_ENCRYPTION_WITH_MITM: Bonding, encrytion and whitelisting with passkey authentication. // #ifndef MICROBIT_BLE_SECURITY_LEVEL #define MICROBIT_BLE_SECURITY_LEVEL SECURITY_MODE_ENCRYPTION_WITH_MITM #endif // Enable/Disable the use of BLE whitelisting. // If enabled, the micro:bit will only respond to connection requests from // known, bonded devices. #ifndef MICROBIT_BLE_WHITELIST #define MICROBIT_BLE_WHITELIST 1 #endif // Define the period of time for which the BLE stack will advertise (seconds) // Afer this period, advertising will cease. Set to '0' for no timeout (always advertise). #ifndef MICROBIT_BLE_ADVERTISING_TIMEOUT #define MICROBIT_BLE_ADVERTISING_TIMEOUT 0 #endif // Defines default power level of the BLE radio transmitter. // Valid values are in the range 0..7 inclusive, with 0 being the lowest power and 7 the highest power. // Based on trials undertaken by the BBC, the radio is normally set to its lowest power level // to best protect children's privacy. #ifndef MICROBIT_BLE_DEFAULT_TX_POWER #define MICROBIT_BLE_DEFAULT_TX_POWER 0 #endif // Enable/Disable BLE Service: MicroBitDFU // This allows over the air programming during normal operation. // Set '1' to enable. #ifndef MICROBIT_BLE_DFU_SERVICE //#define MICROBIT_BLE_DFU_SERVICE 1 #define MICROBIT_BLE_DFU_SERVICE 0 #endif // Enable/Disable BLE Service: MicroBitEventService // This allows routing of events from the micro:bit message bus over BLE. // Set '1' to enable. #ifndef MICROBIT_BLE_EVENT_SERVICE //#define MICROBIT_BLE_EVENT_SERVICE 1 #define MICROBIT_BLE_EVENT_SERVICE 0 #endif // Enable/Disable BLE Service: MicroBitDeviceInformationService // This enables the standard BLE device information service. // Set '1' to enable. #ifndef MICROBIT_BLE_DEVICE_INFORMATION_SERVICE #define MICROBIT_BLE_DEVICE_INFORMATION_SERVICE 1 #endif // // Accelerometer options // // Enable this to read 10 bits of data from the acclerometer. // Otherwise, 8 bits are used. // Set '1' to enable. #ifndef USE_ACCEL_LSB #define USE_ACCEL_LSB 0 #endif // // Display options // // Selects the matrix configuration for the display driver. // Known, acceptable options are: // #define MICROBUG_REFERENCE_DEVICE 1 #define MICROBIT_3X9 2 #define MICROBIT_SB1 3 #define MICROBIT_SB2 4 #ifndef MICROBIT_DISPLAY_TYPE #define MICROBIT_DISPLAY_TYPE MICROBIT_SB2 #endif // Selects the minimum permissable brightness level for the device // in the region of 0 (off) to 255 (full brightness) #ifndef MICROBIT_DISPLAY_MINIMUM_BRIGHTNESS #define MICROBIT_DISPLAY_MINIMUM_BRIGHTNESS 1 #endif // Selects the maximum permissable brightness level for the device // in the region of 0 (off) to 255 (full brightness) #ifndef MICROBIT_DISPLAY_MAXIMUM_BRIGHTNESS #define MICROBIT_DISPLAY_MAXIMUM_BRIGHTNESS 255 #endif // Selects the default brightness for the display // in the region of zero (off) to 255 (full brightness) #ifndef MICROBIT_DISPLAY_DEFAULT_BRIGHTNESS #define MICROBIT_DISPLAY_DEFAULT_BRIGHTNESS MICROBIT_DISPLAY_MAXIMUM_BRIGHTNESS #endif // Selects the default scroll speed for the display. // The time taken to move a single pixel (ms). #ifndef MICROBIT_DEFAULT_SCROLL_SPEED #define MICROBIT_DEFAULT_SCROLL_SPEED 120 #endif // Selects the number of pixels a scroll will move in each quantum. #ifndef MICROBIT_DEFAULT_SCROLL_STRIDE #define MICROBIT_DEFAULT_SCROLL_STRIDE -1 #endif // Selects the time each character will be shown on the display during print operations. // The time each character is shown on the screen (ms). #ifndef MICROBIT_DEFAULT_PRINT_SPEED #define MICROBIT_DEFAULT_PRINT_SPEED 400 #endif //Configures the default serial mode used by serial read and send calls. #ifndef MICROBIT_DEFAULT_SERIAL_MODE #define MICROBIT_DEFAULT_SERIAL_MODE SYNC_SLEEP #endif // // I/O Options // // // Define the default mode in which the digital input pins are configured. // valid options are PullDown, PullUp and PullNone. // #ifndef MICROBIT_DEFAULT_PULLMODE #define MICROBIT_DEFAULT_PULLMODE PullDown #endif // // Panic options // // Enable this to invoke a panic on out of memory conditions. // Set '1' to enable. #ifndef MICROBIT_PANIC_HEAP_FULL #define MICROBIT_PANIC_HEAP_FULL 1 #endif // // Debug options // // Enable this to route debug messages through the USB serial interface. // n.b. This also disables the user serial port 'uBit.serial'. // Set '1' to enable. #ifndef MICROBIT_DBG #define MICROBIT_DBG 0 #endif // Enable this to receive diagnostic messages from the heap allocator via the USB serial interface. // n.b. This requires MICROBIT_DBG to be defined. // Set '1' to enable. #ifndef MICROBIT_HEAP_DBG #define MICROBIT_HEAP_DBG 0 #endif // Versioning options. // We use semantic versioning (http://semver.org/) to identify differnet versions of the micro:bit runtime. // Where possible we use yotta (an ARM mbed build tool) to help us track versions. // if this isn't available, it can be defined manually as a configuration option. // #ifndef MICROBIT_DAL_VERSION #define MICROBIT_DAL_VERSION "unknown" #endif // // Helper macro used by the micro:bit runtime to determine if a boolean configuration option is set. // #define CONFIG_ENABLED(X) (X == 1) #define CONFIG_DISABLED(X) (X != 1) #if CONFIG_ENABLED(MICROBIT_HEAP_ALLOCATOR) #include "MicroBitHeapAllocator.h" #endif #if CONFIG_ENABLED(MICROBIT_DBG) extern RawSerial* SERIAL_DEBUG; #endif #endif
Hello Alex,
It looks like since the microbit did display a tick mark, that it has successfully paired, is that not the case? Are you able to successfully connect to the microbit afterwards? You can take a look at this guide for troubleshooting pairing for the microbit if that is not the case:
https://support.microbit.org/support/solutions/articles/19000069393-bluetooth-troubleshooting-guide
Hope this helps!
-Karen, team Mbed
