7 years, 8 months ago.
STM32L475E-IOT01A1 Heap Size
I am having an app
1) Interfacing UART4 to a board to get some data 2) Publish it to Aws IoT Cloud using MQTT+mbedtls Till this point app works correctly
but I wanted to send onboard (STM32L475 IoT NODE) Sensor data. I tried for only one sensor (part 1)+2) ), I am facing memory problem
/*******/ [DBG ][TLSx]: ssl_cli.c:3240: |1| mbedtls_pk_sign() returned -17168 (-0x4310) [ERR ][TLSx]: mbedtls_ssl_handshake() failed: -0x4310 (-17168): RSA ERROR: rc from TCP connect is -17168 /******/ (which was resolved in the post https://os.mbed.com/questions/81718/Project-Mbed-to-AWS-IoT-on-DISCO_L475VG_/#answer14911)
I tried for "main-stack-size": 3584 but still same problem.If I go below this size I see stack overflow.
Is there any other way to solve this.
7 years, 7 months ago.
Hi, I don't know if this works for you but if you need to reduce memory consumption, you can remove easy_connect from the sample program and directly use ISM43362 Wi-Fi driver. This will reduce 1-2 kB RAM usage. To do this,
Then compile your program and see the behavior.
