7 years, 8 months ago.
ARM integration into the compilation
I have a cryptographic project that I have to do on the STM32L053R8, and I am a beginner in the hardware part (never touched electronic boards before).
My project is written in C and ARM languages and contains 2 makefiles and a lot of header files. I am compiling online with Mbed Compiler and unfortunately I cannot take off the part coded with ARM.
How can I compile my project so it would work on the STM32L053R8 since I've read that the Mbed Compiler only knows Cand C++ and not ARM?
Thank you for your help!
Hi Moss,
You need to export your code to and use an off line compiler. You then need to compile the assembly code and then compile the your C code. This is assuming that you have the correct header file for all your files. Here are some links for your references.
Compiling assembly and C code: https://www.devdungeon.com/content/how-mix-c-and-assembly
Exporting project from Online Mbed to an offline toolchain: https://os.mbed.com/handbook/Exporting-to-offline-toolchains
Instructions on how to install Mbed CLI can be viewed here: https://github.com/ARMmbed/mbed-cli#installing-mbed-cli
Further instructions on how to export your program to your IDE with the Mbed CLI can be viewed here:https://github.com/armmbed/mbed-cli#exporting-to-desktop-ides
- Peter, team Mbed
