7 years, 8 months ago.
TCP Socket can not reconnect
there is a fault when I reconnect a server an send data to MCU used my pc. The frist time, it's OK. Why? here is the code section:
while(1) { /* Can handle x simultaneous connections */ if(srv.listen(1) == 0) { srv.accept(&client_sock, &client_addr); printf("Accepted %s:%d\n", client_addr.get_ip_address(), client_addr.get_port());
Thread::wait(10000); tmpcount = client_sock.recv(buffer, 1024); client_sock.TCPSocket(); printf("closed \n"); } }
Hi, in second run in your loop you want again accept a client without close the client from first loop. So your server waiting for new connection but your client is still connected...
Your code
client_sock.TCPSocket(); // close need here
This is a standart way.
New pseudo code
printf("\nWait for new connection...\n");
if (tmpcount <= 0) break;
printf("Received message from Client :'%s'\n",buffer);;
client_sock.close();
It's only my idea...
