7 years, 8 months ago.
Write int32_t data vector to serial
Hi to everyone. The problem is: I have an IKSa02 expansion board from which I get, through a Nucleo L152RE, accelerometers and gyro data. I would to send those data through a serial port (RS 232) to a PC in order to make acquisition with a program written in VisualBasic (this program gets the data from the serial port and creates a file .bin that I will process later). Now, the data acquired with the L152RE are int32_t, while with the command putc() I can write on the serial a char. My first question is: how can I write an int32_t data into a serial port? I have made a code if anyone wanted to look at it. The structure of the code is: 1) I put all the data from sensors into a vector called "data_vect", which first element is a fixed data called "a"; 2) I send each element of data_vect through the command putc(). I want to know if this approach is correct. I will be grateful for each answer. Thank you.
#include "XNucleoIKS01A2.h"
static XNucleoIKS01A2 *mems_expansion_board = XNucleoIKS01A2::instance(D14, D15, D4, D5);
static LSM303AGRAccSensor *accelerometer = mems_expansion_board->accelerometer;
static LSM6DSLSensor *acc_gyro = mems_expansion_board->acc_gyro;
Serial device(PA_2, PA_3, 115200);
Timer t;
int main(){
    device.format(8,SerialBase::None,1);
    accelerometer->enable();
    acc_gyro->enable_g();
    int32_t acc_data[3];
    int32_t gyro_data[3];
    int32_t t_sample;
    int32_t data_vect[8];
    int32_t a = 123456789;
    int i;
    char *bytePtr;
    int x;
        accelerometer->get_x_axes(acc_data);
        acc_gyro->get_g_axes(gyro_data);
        t_sample = t.read_us();
        for(i=0; i<8; i++){
            if(i==0){
                data_vect[i] = a;            //Dato tipo "start bit"
            if(1<=i<=3){
                      data_vect[i] = acc_data[i-3];
            if(4<=i<=6){
                      data_vect[i] = gyro_data[i-4];
            if(i==7){
                      data_vect[i] = t_sample;
        for(i=0;i<8;i++){
            bytePtr = (char *)&data_vect[i];
            for(x=0;x<sizeof(data_vect[i]);x++){
                device.putc(*(bytePtr++));
    }//end while
}//end main
Hello Nikolaos,
After taking a closer look at your code I think there is an issue with array index.
Rather than
        if(1<=i<=3){
            data_vect[i] = acc_data[i-3];  // when i == 1 or 2 then [i - 3] becomes negative
try
        if(1<=i<=3){
            data_vect[i] = acc_data[i-1];
posted by Zoltan Hudak 19 Jul 2018
It seems that there is more to fix. Also the expressions below won't work correctly.
if(1<=i<=3) {
if(4<=i<=8) {
So I would suggest to rewrite the for loop as follows:
        for (i = 0; i < 8; i++)
            if (i == 0)
                continue;
            if ((1 <= i) && (i <= 3))
                data_vect[i] = acc_data[i - 1];
                continue;
            if ((4 <= i) && (i <= 6))
                data_vect[i] = gyro_data[i - 4];
                continue;
            if (i == 7)
        uint8_t bytes[sizeof(int32_t)];
            *(int32_t*)bytes = data_vect[i];
            for (uint8_t j = 0; j < sizeof(int32_t); j++)
                device.putc(bytes[j]);
Thank you very much! Now it's working properly! I have no words for your help. I am so grateful! May you have a good day.
Best regards, Nikolaos
posted by Nikolaos Dedes 20 Jul 2018
Hello Nikolaos,
I think that your approach to convert the int32_t data items to bytes (uint8_t, unsigned char or char), transmit those bytes over serial link and then convert the received bytes back to int32_t is correct.
  • You should also take into account the endianness. Maybe you have to shuffle the order of bytes (either on the transmitter or receiver side) before converting them back to uint32_t to get correct values.
Thank you for the reply, but it doesn't work. I don't know why, but the data sent on the Serial port are wrong: it's not and endiannes problem. I imagine is a problem of putc() but I don't know what the problem is. What about the "write" command? I cannot understand how to use it; do you have any experience?
posted by Nikolaos Dedes 19 Jul 2018
Generally the code looks ok. I would have used a switch/case statement block instead of all the "if(1<=i<=3)" constructs.
But something looks fishy to me
Normally I would write that
device.putc(*bytePtr++);
So that there is no chance that the compiler will increment before the indirect lookup. Your compiler may generate identical results but I suspect it's pre-incrementing....
Bill
Thank you for the reply, but as I mentioned to the Zoltan's answer, it seems that the serial port send wrong data and i don't know why: i've tryed also with your trick but the result is the same. It's like something was wrong with the serial port RS232. For example: if i send
device.putc('a');
on the USB port (STM-link) it looks ok and the terminal shows me the character 'a'. But if I select the RS232 port on the terminal, it does not appear the character 'a', but strange characters.
