7 years, 8 months ago.
Compiling Error
Error: "/tmp/vx6V3T", line 124 (column 3): Warning: L6312W: Empty Execution region description for region RW_IRAM1 Error: Symbol user_perthread_libspace multiply defined (by /build/mbed-os.lib/rtos/TARGET_CORTEX/rtx5/RTX/Source/rtx_lib.K64F.o and /build/mbed-os.lib/rtos/TARGET_CORTEX/mbed_boot.K64F.o). Error: Not enough information to list the image map.
Hello, I am new in Mbed, I was trying some tutorial. So added a library, and compile it first before even editing the code in main.cpp. it gives me above error.
How would I fix that error and what is the reason behind this error?
Please let me know,
Hello there,
This has been an issue for programs using Mbed OS 5.9.2. There is a github issue that has been raised:
https://github.com/ARMmbed/mbed-os/issues/7422
If you are using the online compiler:
Under the Compile button, navigate to Compile Macros and add _RTE_ in the text box. Then try recompiling.
I was able to successfully compile the program through these steps. Hope this helps!
-Karen, team Mbed
Thank a lot , It did fix the problem.
posted by Mahdiul Chowdhury 18 Jul 2018
Hi there,
I have tried this solution but it is not working. The error still persists, the link to Github just says to do the same thing.
Any other ideas? Thanks
posted by Jacob Horgan 16 Mar 2019
