7 years, 6 months ago.
Setting FFChan settings in ffconf.h from mbed configuration files
Hi All,
I'm currently porting a project from mBed 2 (classic) to mBed 5 (mbedOS).
We are running a threaded application I underwent a small amount of work in the project to get ffChaN using its reentrancy feature This basically involved writing some C function wrappers around Mutexes and changing some defines in the ffconf.h header. The exact define is FF_FS_REENTRANT.
We did this all inside the mbed library by directly changing these files and commiting them to a separate branch.
With the advent of configuration files in mBed, is there any way to set these defines at the mbed_app.json level, or the library configuration? How does one go about finding what configuration settings are available at a library level?
Hi Rupert,
Mbed configuration files are explained here:
If you check mbed-os\features\filesystem\littlefs you will find an example mbed_lib.json file there. You could create your own like that in the mbed-os\features\filesystem\fat to handle your own definitions. Another example of styling is shown here - where macros are simply defined in succession in a more compact format: mbed-os\targets\TARGET_NORDIC\TARGET_NRF5x\TARGET_SDK_14_2\TARGET_SOFTDEVICE_S140_FULL.
Ralph, Team Mbed
