7 years, 8 months ago.
Heart rate demo example error
when compiling the example demo code mbed-os-example-ble-HeartRate and the following error is produced:
Error: Symbol user_perthread_libspace multiply defined (by /build/mbed-os.lib/rtos/TARGET_CORTEX/rtx5/RTX/Source/rtx_lib.MAX32630FTHR.o and /build/mbed-os.lib/rtos/TARGET_CORTEX/mbed_boot.MAX32630FTHR.o).
Any help will be highly appreciated.
Hello there,
There is a github issue that has been raised:
https://github.com/ARMmbed/mbed-os/issues/7422
If you are using the online compiler:
Under the Compile button, navigate to Compile Macros and add _RTE_ in the text box. Then try recompiling.
I was able to successfully compile the program through these steps. Hope this helps!
-Karen, team Mbed
