7 years, 7 months ago.
USB Serial code is stops works after certain scanf
Hi All,
I am evaluating nucleo stm32f401RE board. I develop one basic application using USBStack. I used the USBserial class from that.USB stack downloaded from the below link.
https://os.mbed.com/teams/ST/code/STM32_USBDevice_Serial/?platform=ST-Nucleo-F401RE
Inside a code i am scanning some input from the user. After the some scanf it fail to scan the data. Code stops work and throwing below error.
mbed assertion failed: ret!=HAL_BUSY, file: ../USBDevice/targets/TARGET_STM/USBHAL_STM32.cpp, line 258
This error is from USBHAL_STM32.cpp file 's endpoint-Read function.
Please addressing my below queries for the same, 1) Why USBSerial suddenly stop work? 2)Is this USB stack reliable?
Please let me know if you need more information from my side.
Thanks, Parth
Hi Parth,
The example you linked to is extremely old and is using Mbed OS 2 instead of the latest Mbed OS 5. USBSerial is also no longer supported. However, Mbed OS 5 does have support for Serial/RawSerial drivers, and there are a few examples for Mbed OS 5 that will work with the stm32f401RE board here:
- Serial examples: https://os.mbed.com/docs/latest/reference/serial.html#serial-examples
- RawSerial examples: https://os.mbed.com/docs/latest/reference/rawserial.html#rawserial-examples
- Jenny, team Mbed
Encountered the same problem with the stm32f769 board. Unfortunately, the links you provided doesn't work (anymore). Could you post new, valid links?
/Anders
posted by 26 Sep 2018Hi Anders, I apologize for those broken links. Here's the updated ones:
- Serial examples: https://os.mbed.com/docs/latest/apis/serial.html#serial-examples
- RawSerial examples: https://os.mbed.com/docs/latest/apis/rawserial.html#rawserial-examples
- Jenny, team Mbed
posted by 27 Sep 2018
We ran into the same problem. The driver is full of issues - one being the unbelievable amount of calls going on in ISR context when receiving data. The most problematic is this failure if HAL_BUSY is returned while trying to lock() a given endpoint. That is, if you get an incoming interrupt to read from the endpoint while you are writing to the endpoint, it locks up. You will also see problems when receiving data at higher speeds.
posted by Curt Black 15 Jul 2018Hi Curt Black,
Thanks for you kind reply.
Is there any solution to resolve these?
Please let me know.
Thanks, Parth
posted by Parth Modi 16 Jul 2018
