7 years, 8 months ago.
online compiler won't export to IAR toolchain
I'm trying out the online compiler, and using the ST Discovery DISCO-F469NI. I want to export the code so i can use the IAR toolchain. However, the option is not there in the export-program drop-down list. If i change the export-target to something else, i see the iar option. Is export not supported for the the this board? Dragging and dropping the .bin also doesn't work (nothing happens)
Hello Sean,
Can you make sure that you have selected the right platform when exporting? I was able to export this program example program [[https://os.mbed.com/teams/ST/code/DISCO-F469NI_LCD_demo/?platform=ST-Discovery-F469NI] to IAR for Eclipse, VSCode, and Make.
- Peter, team Mbed
I see all of those options, but none of them generate a project file for IAR embedded workbench IDE - at least not in an obvious way. If i select a different device - for example the NUCLEO-F411RE, this offers the three export targets you see, and an additional 'iar' - which allows me to open a project in the IAR IDE.
posted by Sean Smith 12 Jul 2018
