7 years, 9 months ago.
Error on compiling the mbed-os-example-lorawan app - Compiler Error L6200E - Compiler Error 0
Good day,
I have imported the app into my mbed compiler (Online), but when I try to compile and download it, it throws two errors (and many warnings). I haven't been able to find the mistake.
The description of the erros are: Error: Symbol user_perthread_libspace multiply defined (by /build/mbed-os.lib/rtos/TARGET_CORTEX/rtx5/RTX/Source/rtx_lib.DISCO_L072CZ_LRWAN1.o and /build/mbed-os.lib/rtos/TARGET_CORTEX/mbed_boot.DISCO_L072CZ_LRWAN1.o). Error L6200E.
Error: Not enough information to list the image map. Error 0.
For the first error I realized that the project has two portions of code identical in different files, but those files are .o files and I don't know where to find them in the project path.
I have no idea about the second error.
P.S: I haven't made any kind of changes in the code, it's just as I imported it.
Thank you so much for your help.
Best Regards, Santiago Gil./media/uploads/sagilar/capture.png
Hello Santiago,
There is a github issue that has been raised:
https://github.com/ARMmbed/mbed-os/issues/7422
It seems like Jerome has a found a solution that may work for you. Under the Compile button, navigate to Compile Macros and add _RTE_ in the text box. Then try recompiling. Hope that helps!
-Karen, team Mbed
Thank you for your help.
The solution was to add the _RTE_ macro into the compiler.
BR.
posted by Santiago Gil 06 Jul 2018
I had the same error with the DISCO-F746NG and this solution worked for me also.
posted by Peter Ampt 17 Jul 2018
