7 years, 9 months ago.
mbed complementary pwm single output
how can i design a complementary pwm output of 0.5 duty cyle with mbed mbed lpc1786?
Hi Aman,
Here is an example from the Mbed Drivers Reference Manual, link here https://os.mbed.com/docs/v5.9/reference/pwmout.html
PWMOut
PwmOut led(LED2);
// specify period first, then everything else
led.period(4.0f); // 4 second period
led.write(0.50f); // 50% duty cycle
while(1); // led flashing
As for the complementary pwm output, I don't understand what you mean by that. PWM is technique for controlling analog circuits with a microprocessor's digital outputs, which you can learn it herehttps://www.embedded.com/electronics-blogs/beginner-s-corner/4023833/Introduction-to-Pulse-Width-Modulation. So it does not matter if you are inverting it or not because the outcome result will still be the same. That being said, the Mbed API does not support complementing PWM signal. To do that, the easiest way is to run the pwm output through an external hardware inverter.
- Peter, team Mbed
