7 years, 9 months ago.
mbed OS version: unknown
what do i need to in order to specify "mbed OS version" which is just under title of imported library?
Hi Pavel,
The Mbed OS version of a program is specified in the link of the Mbed OS repository in the mbed-os.lib file. So for example, I import mbed-os-example-blinky onto my computer or into the Online Compiler. I look in the mbed-os.lib file and I see a link to the Mbed OS GitHub repository. The long strand of numbers following the "#" in the URL signifies which version of the Mbed OS repo the program is using. I can then match up that string to a revision number associated with a release tag here: https://github.com/ARMmbed/mbed-os/releases
If you are using the Mbed CLI you can find the version number of the Mbed OS library with the following commands:
cd [Your Project Folder]
cd mbed-os
git branch
And this should print out the full version number of the Mbed OS library you are using (i.e. mbed-os-5.9.1).
You can also print out the version numbers of your Mbed OS library within your application code by using the following printf statment:
printf("mbed-os version: %d.%d.%d\tlibrary version: %d\r\n",
       MBED_MAJOR_VERSION, MBED_MINOR_VERSION,
       MBED_PATCH_VERSION, MBED_LIBRARY_VERSION);
- Jenny, team Mbed
