7 years, 9 months ago.
Disable interfaces
Hello.
I need to activate a serial port or SPI port, send some data and after that disabe the interface to reduce the power until I don’t need it. How can I do this?
Thank you in advance.
Regards.
Hi Jorge,
Mbed is currently working on an API that allowed you to enable and disable peripheral. Therefore, we currently have no direct way to disable any peripheral. You can however make a function that create the peripheral when called and destroy that peripheral when exit.
void peripheral(){
SPI spi(D11, D12, D13); // mosi, miso, sclk
DigitalOut cs(D0);
// Chip must be deselected
cs = 1;
// Setup the spi for 8 bit data, high steady state clock,
// second edge capture, with a 1MHz clock rate
spi.format(8,3);
spi.frequency(1000000);
// Select the device by seting chip select low
cs = 0;
// Send 0x8f, the command to read the WHOAMI register
spi.write(0x8F);
// Send a dummy byte to receive the contents of the WHOAMI register
int whoami = spi.write(0x00);
printf("WHOAMI register = 0x%X\n", whoami);
// Deselect the device
cs = 1;
void main(){
while(1){
peripheral();
wait(1000);
- Peter, team Mbed
