7 years, 8 months ago.
How to connect maxrefes117# to Max32630FTHR board ?
In the maxrefdes117# reference design guide it show us how to connect to MAX32600mbed# port and other modules. But I would like to connect to MAX32630FTHR module. Would you please show me the port to connect to MAX32630FTHR? I assume I can use any I2C bus.
Thanks
Stan
Hello Stanley,
You should be fine with following the standard connections for an I2C bus. Here is a detailed example of a project that demonstrates how to connect the board and reference design together (under the "Wiring the Board and Reference Design" section):
https://www.electromaker.io/project/view/creating-a-wearable-heart-rate-monitor
You can also refer to the data sheet for the MAX32630FTHR for other connection options:
https://datasheets.maximintegrated.com/en/ds/MAX32630FTHR.pdf
Hope this helps!
-Karen, team Mbed
